The other day some one asked me how do I add carpet to the bottom of a door panel. I wanted to share with you my steps on how I do this. Basically what you need to do this instead of making another panel with ABS and covering it with carpet (Because the carpet is so thick)
- First you cut the carpet to the exact shape you want to fit the door panel.
- Glue this carpet to chipboard and trim flush the chipboard to the carpet.
- Then finish only the top edge with binding (unless you have metal trim that covers this seam).
- Then sew a strip of vinyl to the edge of the carpet section. like this picture here.
- Now glue and position the carpet on to the door panel. Use a little extra glue on the top edge to make it really strong.
- Now pull the vinyl strip you sewed on around the edge of the door panel. Pull it tight and even and staple it down. This will give you a really nice finished edge and will sit flush with the rest of the door panel.
Hope this helps!
kl4bidn, LeatherJohnny liked this
#1554
Thanks for the explanation!! :wink:
John wrote: Mon Jun 18, 2018 7:47 pm I use size 92 on carpet. I use size 92 for basically everything unless I want a thicker top stitch for decoration.
One question about that, please:
Given that thread numbers/sizes are different in the US and Europe, I would like to know if you use the 92 thread with a needle size 18?
If you do, the thread size that I use with this needle is the European number 30, which is fairly thin, and with this information, I'd have more info about what thread to use, and when... I wish we had the same numbers all over the world, because it would be much easier for everybody in Internet!!! :joy: :joy: :joy:
Thank you very much in advance! :wink:
#1600
Haha yeah needle and thread sizes make me a little crazy with all the mixed information out there.
Here is some needle / thread size information hopefully it helps.
Size 15 / Tex 16 / Govt. 00 - Use needle sizes 70 / 10 to 80 / 12
Size 33 / Tex 35 / Govt. AA - Use needle sizes 80 / 12 to 90 / 14
Size 46 / Tex 45 / Govt. B - Use needle sizes 90 / 14 to 100/ 16
Size 69 / Tex 70 / Govt. E - Use needle sizes 100 / 16 to 110 / 18
Size 92 / Tex 90 / Govt. F - Use needle sizes 110 / 18 to 125 / 20
Size 138 / Tex 135 / Govt. FF - Use needle sizes 120 / 19 to 140 / 22
Size 207 / Tex 210 / Govt. 3-Cord - Use needle sizes 140 / 22 to 180 / 24
Size 277 / Tex 270 / Govt. 4-Cord - Use needle sizes 180 / 24 to 230 / 26
Size 346 / Tex 350 / Govt. 5-Cord - Use needle sizes 230 / 26 to 280 / 28
Size 415 / Tex 410 / Govt. 6-Cord - Use needle sizes 280 / 28 to 330 / 30
Size 554 / Tex 600 / Govt. 8-Cord - Use needle sizes 330 / 30 to 360 / 32
I got this from here. http://www.thethreadexchange.com/miva/m ... size-chart
I also did this video a little while back. It might help.
LeatherJohnny, Bondo497 liked this
#1608
Wow!!! Thanks a lot for the information! The thread exchange is a very good website for everythng related to our hobby/job!
When I ordered needles online, I purchased two types (D and S) of sizes 18, 19, 20, 21, 22, 23 and 24, and also a box of LR size 25, but I have used mostly 18 for closing seams and 21 and 22 for french seams. I'm still learning and practicing! :relieved:
What you explain in this video is really useful. Very well explained and very easy to understand!!! Thanks again! :wink:
kl4bidn, John liked this
another motorcycle seat
Looks amazing!
